- June 3, 2025 at 12:22 pm #158454
George Wright
I have determined that Total Cache interferes with the Enlarge on Click function and perhaps other picture sizing features in WP. Are there any hints you can provide on where to begin within the settings to debug?
This plug-in did really help to improve the site speed. I would like to keep as much of that as possible.
~george wrightJune 3, 2025 at 12:32 pm #158471Marko Vasiljevic
KeymasterHello George,
Thank you for reaching out, and I am happy to help!
Can you please share an example of the page you are having issues with?
Can you please disable the settings one by one in the W3 Total Cache Performance>general settings, save the settings and purge the cache after each setting is disabled and see which one might be causing the issue?Thanks!
June 4, 2025 at 9:44 am #158507George
GuestProblem is with minification of JS. I tried various combinations of settings including “Blocking”, minify only, etc. Only disabling JS minify settings resolves the issue. But Jquery shows up in speed tests as render-blocking resource.
June 4, 2025 at 9:45 am #158511Marko Vasiljevic
Thank you for your feedback
If convenient and for a quick test, can you please add the path below to exclusion in the minify settings, Performance>Minify>Advanced>Never Minify following JS file,s and let me know if the problem still occurs?/wp-includes/js/dist/script-modules/block-library/image/view.min.js
June 5, 2025 at 12:29 pm #158563George
GuestThat exclusion worked! Thanks for the help.
~gJune 5, 2025 at 12:29 pm #158575Marko Vasiljevic
You are most welcome!
We would really appreciate it if you could take a minute and post a review here. This will help us to continue offering a top-notch product to users.
Thanks!June 6, 2025 at 7:12 am #158587George
I appreciate the quick and helpful response to my enquery.
~g - AuthorPosts
- The topic ‘Total Cache breaks “Enlarge on Click” for photos’ is closed to new replies.
